Norma; 'boot sequence' for a CPU?
Discussion in 'Electronic Basics' started by phil, Oct 29, 2004.
  1. phil
    phil Guest
    I'm curious, please indulge me - what is the normal 'boot sequence'
    for your average old CPU?
    Let's take a Z80 for example - when a board with a Z80 (and relevant
    RAM, ROM and support chips) is powered on, what is the sequence of
    events that takes place?
    Does the CPU, for example, first expect an interrupt from some other
    part of the circuit? Does it immediately try and access RAM or ROM via
    the address lines? Etc.
    Or is there a web site somewhere with this info?
    I'd really like to know this as it will help my understanding
    considerably.
    Phil
  2. Tom Biasi
    Tom Biasi Guest
    Its been quite a while since I messed with a Z80.
    You might try your question here:comp.arch.hobbyist
    Regards,
    Tom
  3. It starts running, reading the first RAM memory address.
    Probably
  4. phil
    phil Guest
    Cheers, will do. All advice welcome. :)
  5. Active8
    Active8 Guest
    reset sequences/modes vary from proc to proc and family 2 family,
    clearing and setting initial register values and perhaps leaving
    others alone or undefined.
    IIRC, some of 'em had the reset vector high, no?
    processors don't "expect" ints per se, but you can enable and
    disable some/most, sometimes all ints by writing a control register.
    Let's not forget those data/io lines.
    Those spec sheet thingies? My best suggestion is for the OP to start
    reading those. They're priceless and free.
  6. The Z80 reference manual:
    http://www.zilog.com/docs/z80/um0080.pdf
    Inside that pdf file, look at page 28, a minimum system.
    See the reset circuit connected to the -reset pin, it is only a resistor from plus 5 Volt and a capacitor to ground.
    When the power supply starts the capacitor is charged, and Z80 starts.
    It then starts executing the first RAM memory address.
  7. John Larkin
    John Larkin Guest
    But there's nothing in RAM yet. That would be insta-crash.
    Most CPUs fetch a vector (start pointer) from a fixed location in ROM,
    which then starts executing BIOS code in ROM, which will eventually
    copy the OS from a disk file into RAM and jump into that.
    John
  8. Guest
    Following a reset, the Z80 will go to address 0000 and begin to execute that
    code. If its RAM, its a problem :) The EPROM will be mapped to that address.
    In the early days of 8 and 16 bit CPUs, the restart address was often 0000,
    but some, like Motorola start at the highest memory address. Where that
    address is on the newest generation, I don't know for sure, but I would
    venture a guess that the Intel family goes to 0000 and Motorola goes to the
    highest address. Its hard to teach old dogs new tricks. :)
    John
  9. The processor fetches and instruction from a specific location in
    memory (location 0 for the 8080/Z80, may be elsewhere for other
    processors). What happens after that depends on the instruction it
    finds, and on the rest of the program.
    Consult the databook for the processor you are interested in.
  10. I have used static RAM as ROM myself, that is why I said RAM.
    Most people would maybe call a programmed memory a PROM, even if it
    actually is a battery-backed static RAM, which is a lot easier to handle
    for experimental work, because there is no need for a special programmer
    or eraser.
    And it doesn't crash, if the first address is empty or not connected it
    will just try the next address.
    If I recall correctly a memory content of nothing, zero, makes the cpu
    execute a NOP, a no operation operation, and it goes on to the next
    address.
    Even if you have no memory connected you can see the addresslines count
    up, trying to find some content other than zero.
    Maybe I should add that my knowledge in this field is 20 years old, and
    maybe not correct in all details. It was in 1984 I was playing with a
    Z80 and static RAM. And I am too lazy to check it up now. :)
  11. Basically, just think of the CPU as having some internal registers and control
    bits that are initialized to specific values as the CPU comes "out of reset."
    (Most processors have a carefully designed reset state, preceding the moment
    when they actually start to 'run'.)
    Some CPUs will set their instruction pointer to 0, some to a 'large number', but
    all of them set it to a predictable value before they start executing.
    Sometimes, this points to some memory inside the CPU. Sometimes, to external
    memory (suggesting the CPU actually supports an external memory bus.) Either
    way, this memory hopefully will be non-volatile memory of some kind. It's up to
    the system designer or the programmer to make sure that some useful code is
    there.
    What happens after that will depend on the code.
    In your IBM PC, it's the BIOS flash or ROM that sits at this point and helps to
    start up your PC. In many embedded systems, using small microcontrollers, it's
    entirely code you write for your application, forced to be placed at the right
    location by a locating linker.
    Jon
  12. That simply cannot be. The 'first' RAM address contains garbage data
    since it was just powered up. I suspect the reset vector points to a
    ROM address and execution procedes from that instruction. I'm not
    familiar with the Z-80, only MCS-51 and 6805/08 bugs but those two are
    essentially the same. The Moto bugs get the reset vector programmed
    in. The MSC-51 bugs have fixed vectors but you must execute program
    from a known value i.e. EPROM/PROM/flash/non volatile, etc.
    GG
  13. Not if it is a programmed static RAM, which then works just like a
    ROM/PROM.
    After reset it starts from memory location zero, and executes the
    instruction it finds there. What kind of memory, in a technical sense,
    you are using doesn't matter, static RAM, ROM, PROM, EPROM, hardware
    switches, diode matrix, or whatever.
    (You probably associated to dynamic RAM when I said RAM, but there are
    other kinds of RAM memory, which can have a predictable (programmed)
    content.)
  14. Rich Grise
    Rich Grise Guest
    A Locating Linker? Sheesh! I just wrote my code right at its target
    address. My assembler would generally put out a .hex file, which I'd
    send to the programmer or emulator.
    Cheers!
    Rich
  15. Rich Grise
    Rich Grise Guest
    As long as what it's getting is a NOP.
    In 8086, 00H is MOV AX,WORD PTR{BX}. NOP is 90H. :)
    Cheers!
    Rich
  16. That is one of the reasons why I prefer Zilog :)
  17. Jamie
    Jamie Guest
    if memory serves, the 0700:0000 rings a bell.
    or something like that as to where the
    boot loader gets it code loaded into form the
    boot sector.
  18. Some assemblers do that. Particularly, if they are used in cases where they do
    NOT support multiple source code files per project. Most systems that support
    multiple source code files and separate compilation/assembly use a locating
    linker, even if you don't see it operating (which you often don't, unless you
    know what to look for.)
    Jon
  19. Have you actually done this or is this an assumption? You might note
    that I DID mention several varieties of memory that would be usable
    for boot code. You say that 'static RAM' would be OK and that is just
    not the case. Static RAM is only static as long as the power is on.
    Obviously a battery backed static RAM (non volatile RAM) could work.
    From a powered off condition, the RAM contents is random garbage and
    is useless as code.
    The start address is device dependant and may or may not be '0'. For
    example, the 68HC908 reset vector is $FFFE. The value stored there is
    the address to begin execution. For that bug it is most certainly not
    0.
    The 8031 does start at 0 but since the other vectors are in the low
    addresses, you need to jump to the start of the code.
    gg
