noob trying to use a SSR with low voltage
Discussion in 'General Electronics Discussion' started by rbrooks, May 17, 2012.
  1. rbrooks
    rbrooks
    34
    May 17, 2012
    Hi.
    As the title says, I have a solid state relay that I'm controlling with a 24 prox switch.
    It's working fine, but the voltage I have to control is low: 5vdc reference voltage.
    It's having a switching action, but only from 5v on, to 3v off.
    Can you use, for lack of a better term, a pull down resistor to get a more positive TTL type reading? 5v on, but 0v off?
    If so, how would one calculate the necessary resistor value? At the moment, all I have is a 249 ohm resistor and it's not doing it.
    Thanks in advance for any help.
  2. GreenGiant
    GreenGiant
    842
    7
    Feb 9, 2012
    Having a more complete picture of the circuit would help a lot
    Im assuming that by "24 prox switch" you mean a 24V proximity switch, so you are using a relay that is controlled by 24 VDC and controls 5VDC
    I have some suggestions but like I said I need to see your circuitry
    for now try putting the circuit as follows...
    5VDC supply --> resistor (249 is fine to try for now) --> relay --> ground
    then attach the reading element (im assuming microcontroller of some sort) to the point in between the resistor and relay
  3. rbrooks
    rbrooks
    34
    May 17, 2012
    Here's what I have and am conceiving.
    With no resistor, the VOM reads 5v when the relay is activated, but due to it being a SSR, the relaty allows voltage to pass even when the relay is off.
    What I'm hoping is to put a resistor in the loop, so that when the relay is in the off condition, the current will just go across the resistor back to - rather than across the relay.
    I guess I would need to know the resistance value of the open relay, right?
  4. rbrooks
    rbrooks
    34
    May 17, 2012
    I tried your scheme with the 249 and got 2.5v open, 5v closed. Closer to what I need, but there's a bit of float. I was thinking a pull down would give me 5v and 0v.
  5. GreenGiant
    GreenGiant
    842
    7
    Feb 9, 2012
    I see what you are trying to do
    The voltmeter is hooked up incorrectly
    And the resistor where you have it wont really do anything
    I have attached a modified wiring that would indicate on the voltmeter when it is tripped
    what is your end goal with the other side of the SSR?
  6. GreenGiant
    GreenGiant
    842
    7
    Feb 9, 2012
    Try a larger resistor, there is math to figure out the size that you need but its more complicated than is worth getting into with this sort of project
    Try something around a 1K or 5K range
  7. rbrooks
    rbrooks
    34
    May 17, 2012
    I am sending a signal to a National Instruments DAQ system. It operates on 5v max. Basically my application will look for this 5v signal and change a condition. When this switches off, it would change the condition again.
    I suppose I can make it work with 5v and 2.5v, or any two distinct numbers, I was just hoping for more of a positive transfer, IE, the steady 5v that I get and a steady, quick-switched 1v or something. More likely to avoid bounce or false readings if it's two distinct numbers.
    If I'm making any sense.
  8. rbrooks
    rbrooks
    34
    May 17, 2012
    I connected it the way you have described, and it definitely gives me 5v and 0v, just on the inverse of what I was thinking. When the relay is on, I get 0v. When it's off, I get 5v.
    I can work with that. 249 ok for the resistor or should I use a different one?
  9. GreenGiant
    GreenGiant
    842
    7
    Feb 9, 2012
    249 should be fine
  10. rbrooks
    rbrooks
    34
    May 17, 2012
    Wonderful. I have piles of them around here.
    Thanks much for the assist. I've used pull up and pull down before with reed sensors and collectors but nothing like this.
