noob question,easy answer
Discussion in 'General Electronics Discussion' started by turbogt16v, May 19, 2015.
  1. turbogt16v
    turbogt16v
    173
    4
    Mar 27, 2015
    Hy i just bought DC DC Converter Step Up Boost Module 3V To 5V 1A USB Charger For MP3 MP4 Phoneusb charger.
    specs are
    Module Properties: non-isolated step-up module (BOOST)
    input voltage: 2.5-6V
    Output voltage: 4-12 V(Adjustable, the default 5 v)
    Output Current: the maximum 1000mA
    Efficiency: Up to 92% (the higher the input voltage, the higher the efficiency)
    Switching frequency: 1MHz
    Output ripple: 20mV (MAX)
    Operating Temperature: Industrial (-40°c to +85°c)
    Voltage regulation: ± 2.5%
    so my question is when i power some device with correct voltage but weigher amperage what would happen.
    if i power this device with 5v 3a would it burn
  2. davenn
    davenn Moderator
    13,387
    1,785
    The device will only draw the current it needs
    you can put a device requiring 1 amp on a 20 amp power supply if you wish
    always ensure the voltage is the correct one
  3. turbogt16v
    turbogt16v
    173
    4
    Mar 27, 2015
    thank you for swift answer,this has been bugging me a while
  4. davenn
    davenn Moderator
    13,387
    1,785
    its an extremely common question on many forums
    usually because those asking the question haven't got around to learning the basics
    do some google searching on Ohms Law and how it relates to resistance, current and voltage :)
