Tyler Durdem
- Nov 16, 2014
- 7
- Joined
- Nov 16, 2014
- Messages
- 7
Hello Everybody,
This is my first post, I'm looking for a long term place to lurk so I am glad to find this site. I'm getting into small electronic projects but this time I have a stressful repair for myself that popped up and need some help.
I have an industrial printer, I went to turn it on and there was no power at all. I replaced the main fuse cause it was burnt out and then the power resister fried as soon as I plugged it in.
I need to get this thing back up and running, so I can work.
The other problem I found with my meter was a bad transistor. I don't know what caused the problem but I suspect the printer turned on for a self cleaning over night and it is possible a servo motor was stuck and blew something. That's all I can think could of happened, because it worked perfect the day before.
Anyhow, Im trying to replace parts and fix this thing.
My questions are, what is the best replacement for the burnt resistor. I can't find an exact, See pic, I don't want to cause more damage.
The transistor pictured is hard to come by, what would be a good replacement spec wise? What else should I check for, I'm very worried other parts are fried or when I put it back in It could break again or damage another board. This printer has like 5 circuit boards. Its a large roland 545ex.
I'm not good at testing, I just happen to be lucky to find the bad transistor when compared the the same one next to it. This is the power board for the printer.
Any help or suggestions welcome. I tried to find a local tech but all that you can find now are ipod repair places.
Thank YOu
Thank YOu
