Noob DPDT question
Discussion in 'Electronic Basics' started by Wantomeeto, Dec 19, 2003.
  1. Wantomeeto
    Wantomeeto Guest
    I have a guitar effects pedal and want to tie in to 4 small pushbuttons
    (each has 4 connections to the CB) and actuate the contacts from a remote
    location. I am baffled as to why they would need 4 connections for a simple
    pushbutton. Can I simply short 2 and 2? I really want to hack one of
    those cheapy playstation controllers for this project.
    Any ideas?
  2. tempus fugit
    tempus fugit Guest
    Are you sure there are 4 different connections? I'm guessing that controller
    is using tactile switches - they often have 4 legs to mount to the circuit
    board. In this case, there are only 2 connections (minimum requirement for a
    switch), or more accurately, 2 pairs of connections.
  3. Wantomeeto
    Wantomeeto Guest
    Interesting point. I will check the circuit board to verify this. It makes
    sense though - thanks~!
