Jenalee said:
To make a non-volatile software programmable DIP switch. Anyone? Like
those non-volatile digital potentiometers.
Jenalee K.
If its simply for setting options for a processor, the standard solution
is an eeprom.
If you want to actually use the paths through the switch as current
carriers to other devices, you need to implement that with a processor,
and still store the settings in the eeprom.
If there are still any parallel eproms around, you can just use one to
set the control lines of a cmos switch directly.
Regards,
Adrian Jansen adrianjansen at internode dot on dot net
Design Engineer J & K Micro Systems
Microcomputer solutions for industrial control
Note reply address is invalid, convert address above to machine form.
