The following 13.5W LED bulb is mains connected but is it definitely non-isolated?...........
http://www.feit.com/led-lamps/performance/dimmable/a-shape/a19-om800-led
....At time 20:52 of the following, is this the proof that its not isolated?....
..also, if you view from time 6:34 of the above video , you can see that the MCPCB that contains the (non-isolated) led circuit is literally lying right on the heatsink which which appears to be opening out to the external of the bulb
is The electric circuit used is as on page 15 of the following pdf? ........
SSL2103 pwm controller from nxp
http://www.nxp.com/documents/data_sheet/SSL2103.pdf
