Nokia 447x repaired
Discussion in 'Electronic Repair' started by James Sweet, Nov 15, 2004.
  1. James Sweet
    James Sweet Guest
    Had this thing sitting in my garage for over 4 years assuming it was the
    same problem as one I ended up scrapping. Turned out it was a fairly easy
    fix.
    Symptoms: Monitor powers up, bright vertical line
    Problem: HOT shorted, P channel mosfet on a copper heatsink to the
    upper-right of the HOT, also shorted. 1 ohm fusible resistor nearby open.
    Replaced said parts and the monitor now has a beautiful picture.
