Noisy TV
Discussion in 'Beginner Electronics' started by Barry, Jul 18, 2004.
  1. Barry
    Barry Guest
    I have a television which has begun to emit a high pitched sound. It comes
    and goes but mostly it is present. Peering in through the gaps in the case I
    can see something glowing. Is this normal?
    Could dust or something be causing the problem?
    Any help would be appreciated.
  2. Art
    Art Guest
    Hi Freq noises could be from the SMPS, LOPT, YOKE, various inductors and
    even ferrite beads within the tele. Definitive diagnosis necessary to
    determine what is causing the annoying noise. BTW you probably are seeing
    glow of the kine filaments.
  3. Barry
    Barry Guest
    Thanks, it is driving me around the bend, plus dogs from miles around are
    congregating on the front lawn.
  4. Art
    Art Guest
    Fix is to determine just what is causing the noise then applying either a
    serlant of glue to stop it from vibrating. Ocassionally just resoldering the
    item to the circuit board will cure the problem.
