Noise in audio + opamps
Discussion in 'Electronic Design' started by Dirk Bruere at NeoPax, Mar 5, 2007.
  1. Looking at the OP37 (for example) with a noise figure of 3nV (root
    Hz).
    If I were using this as an audio pre-amp with a gain of 5 how does
    this translate into the kind of S/N figures usually specced for amps
    eg -NN dB ?
    Dirk
  2. You have to do the sums
    http://focus.ti.com/lit/an/slod006b/slod006b.pdf
    page 150 gives you the lowdown.
    depends on source Z, bandwidth, temperature etc. +-1audiophool
    martin
  3. Thanks
    Quite interesting.
    Dirk
  4. Eeyore
    Eeyore Guest
    The first thing you need to do is specify the reference level for measurement !
    National's 'Audio Handbook' deals with all of this reasonably well including a
    discussion of adding the effect of source impedance and the influence of bias
    currents (noise component of ) too.
    Graham
  5. I'm just looking for a noise free way to adjust non standard line-in
    to non-standard line-in!
    Since the gain will be very unlikely to exceed a factor of 3 maybe
    just a common emitter transistor as an amp?
    I really want very little noise and to run from a 5V computer PSU.
    I expect this is where someone mentions noise on the 5V, rejection
    ratios and all that.
    Alternatively a neat 5V opamp solution would be appreciated.
    Dirk
  6. Joerg
    Joerg Guest
    Many devices from the TI (formerly Burr-Brown) OPA series seem to be
    suitable but during a recent similar search I found lots of them to be
    out of stock. AD has nice low noise amps that are higher in BW but be
    careful, many of them cannot tolerate more than a diode drop in
    differential input. Might not be an issue for a linear amp but other
    than a small hint in the text there was no mention of that.
  7. Eeyore
    Eeyore Guest
    Do you really want to crush your audio performance ?
    5V isn't enough to run pro-level audio without clipping. Heck, it's not even adequate
    for CD level outputs (2V rms @ 0dBFS) !
    You should use a split supply too unless you really want to make life hard for
    yourself.
    The good news is that supply noise isn't too much of a problem with op-amp circuitry.
    You're going to have to think this one through a bit more thoroughly.
    Graham
  8. Eeyore
    Eeyore Guest
    The standard commodity NE5532 or NJM4560/80 is way more than adequate for line level
    applications.
    Esoteric stuff isn't needed.
    Graham
  9. Fred Bartoli
    Fred Bartoli Guest
    Eeyore a écrit :
    With 0-5V supply it might be so :)
  10. Joerg
    Joerg Guest
    Yep, the NE5532 needs at least +/-5V.
  11. Eeyore
    Eeyore Guest
    5 volt supplies are a non-starter for serious audio.
    Graham
  12. Joerg
    Joerg Guest
    It'll be tough. I am currently doing one and it will have +/-12V.
  13. Eeyore
    Eeyore Guest
    That's reasonably OK as long as you're not doing any serious summing typically.
    +/- 15V is more the norm but I run my own supplies at +/-17 V to get that
    elusive last dB or so of headroom. Even so, the internal signal levels I usually
    normalise to -6dB wrt external levels.
    Graham
  14. Chris Jones
    Chris Jones Guest
    You need to think about the impedance of the source before choosing the
    op-amp, in case you have not already.
    You would probably benefit from reading Douglas Self's books, in case you
    don't already have them. On page 83 of "Self on Audio" he mentions that in
    one particular circuit, the 5532 was measured to be quieter than an OP-27,
    even though the datasheets would lead one to expect the opposite. I think
    it is something to do with the bias current cancellation scheme in the
    OP-27/OP-37 which introduces common-mode noise current, though that only
    matters when the impedance presented to the two input pins is not equal.
    Here is some stuff about op-amps and audio
    http://www.dself.dsl.pipex.com/ampins/webbop/opamp.htm
    Chris
  15. Joerg
    Joerg Guest
    So what's your opamp du jour for this stuff? AFAIK the NE5532 doesn't
    come in TSSOP and not in quad pack. If something doesn't migrate to
    TSSOP these days I become a bit concerned about remaining production life.
  16. I'm feeding into a soundcard on a PC, so it's not rocket science.
    The best I've found is this:
    http://www.analog.com/UploadedFiles/Data_Sheets/738738312AD8099_pra.pdf
    1nV/rtHz isn't bad.
    Dirk
    http://www.onetribe.me.uk - The UK's only occult talk show
    Presented by Dirk Bruere and Marc Power on ResonanceFM 104.4
    http://www.resonancefm.com
  17. john jardine
    john jardine Guest
    The cheap TS974/2/1/ (Farnells) does a nice 4nV-root hz.
    Wide bandwidth, low distortion and runs down to +/- 1.35V.
    Used 8 in series for a particular x100,000 bandpass filter (30kHz bandwidth)
    and was seeing 100mVpkpk noise at the output. (as should be).
    john
  18. Eeyore
    Eeyore Guest
    The 5532 wasn't originally available in SMT because AIUI the die used to be too large.
    It is now however available in SOIC and has been for some time.
    The other regular candidates are the NJM 4560 and 4580 along with the venerable TL07x.
    I rarely use any of the esoteric stuff since I'm normally designing for low cost and
    the above do a fine job.
    Graham
  19. Eeyore
    Eeyore Guest
  20. Because I'm already outputting from it.
    See other thread:)
    Dirk
