N
Nicholas Kinar
Hello--
To preserve bandwidth and slew rate I've selected a high speed op amp
with low wide-band voltage noise and current noise. The 1/f noise is
only 7nV/Hz^(1/2) at 10 Hz, which makes the part suitable for lower
frequency signals extending to DC.
However, the input offset voltage is typically 40 microvolts (300
microvolts max), which may need to be nulled since the op amp is being
used in a non-inverting configuration with high voltage gain.
On my schematic, I have the op amp wired up in a non-inverting
configuration. At the negative input, the feedback resistor is
connected to the output and another resistor is connected to ground.
I've also connected another resistor (with a value of 1 Megaohm) to
this negative input. The terminal of the resistor that is not connected
to the negative input is connected to the output of a 16-bit buffered DAC.
The idea is that the DAC will be used to adjust the voltage at the
negative input, thereby nulling the offset voltage without using a trim
pot. After shunting the positive input of the op amp to GND via a CMOS
switch and load resistor, I'll use a microcontroller to sample an ADC
connected to the op amp output and a minimization algorithm to select
the proper voltage required to reduce the input offset.
However, I'm concerned about whether the 1 Megaohm resistor will inject
significant noise into the feedback loop. Although I know how to
calculate the noise density created by a very large 1 Megaohm resistor,
I am wondering if this noise will be amplified by the op amp feedback.
If so, then is there a way to reduce this noise? Might an RC filter be
an applicable way to go? How do you reduce noise created by a
mechanical trim pot?
