No Voltage Release switch "NVR"
Discussion in 'Electronic Components' started by Speedskater, Feb 13, 2007.
  1. Speedskater
    Speedskater Guest
    Is there any US equivalent to a "No Voltage Release" switch?
    Kevin
    remove the zeppelin to rely.
  2. Prepair Ltd
    Prepair Ltd Guest
    You can make up something similar with a contactor with holding contacts and a
    single-push reset switch. Contactor is started by closing the single-push reset
    switch, holding contacts hold it on (!) if the supply fails it will not close on
    supply restoration unless the reset switch is pushed.
    A lot of motor starters have this feature as standard.
    Peter
  3. Speedskater
    Speedskater Guest
    I know.
    That's what we first thought of in another group.
    Then someone in the UK suggested using a NVR switch.
    See:
    http://orion.quicksytes.com/viewtopic.php?t=436&postdays=0&postorder=asc&start=15
    Kevin
