no uhf receptions
Discussion in 'Electronic Repair' started by Dave, Apr 13, 2007.
  1. Dave
    Dave Guest
    Hello, I can reciecve channels 6-13. But I can't receicve anything
    from 14-58? Can you help me/ Dave Miller.
  2. Make and model and vintage and signal source or sources would be helpful.
    Some receivers have separate tuners ... the UHF tuner might be bad or ...
    lots of stuff!
  3. spam
    spam Guest
    Are you connected to an antenna or cable? If antenna, is a UHF antenna
    connected to the UHF tuner input? Is the TV switch set to antenna, not
    to cable?
  4. Randy
    Randy Guest
    not much info to go on but first i would check to see if you have a
    uhf antenna connected, then i would check to see if you have power to
    the uhf section of the tuner (im guessing its a varactor tuner)
