B
BigTom
AWA C4821 Chassis 4859800990-11
the only thing that works is the small led channel indicator.
it has 2 fuses, a 4amp(still ok) and a 1amp(blown)
Q801 str5412 (shorted)
D807 R2KY (shorted)
C429 4.7uF 160v (high esr)
C806 100uF 16v (high esr)
im not sure about the horizontal output transistor Q402 D1555
the datasheet says it has a damper diode built in.
B-C junction looks ok but B-E gives me 55ohms (both ways)
my questions are
1. is the transistor ok?
2. is there anything else i should look at on this set?
D807 R2KY (shorted)
my questions are
