partyanimallighting
- Oct 22, 2012
- 330
- Joined
- Oct 22, 2012
- Messages
- 330
Hi wise ones,
I've got a fog machine that's completely dead, not powering up at all. The model is a Chauvet Geyser RGB and it can be mounted to output upwards, downwards or sideways and it also has an RGB LED output to illuminate the fog in different colors. The PCB controls both the fog output via DMX and the LED output and the colors can be set on the LCD display or controlled via DMX also. I've torn apart the unit and have checked the PCB out a little. The main components consist of the PCB, a separate 36VDC power supply installed next to the main PCB that feeds DC back into this PCB (this DC input voltage probably deals with the LED side of the unit, outputting to the diode plate) and lastly, there's the heater block. On a working unit, on start up, you get a loud relay click, the LED's flash and the display states "HEAT", signalling that the heater is warming up. There are also tiny operating LED diodes that illuminate green and red on the PCB, signalling functionality. But I'm getting nothing out of this one. On powering up, I've checked AC voltage at the input terminals so far and that's fine so there's no problem with the power cord, fuse etc. but when I check voltage at the heater output terminals, it's reading between 8 and 9VAC and none of the LED's on the PCB are illuminated. There is also no click from the relay, which I assuming sends 110VAC to the heater to start the heat up process. The unit apparently also utilizes 2 pumps, a main pump that outputs fog fluid to the heater, and a smaller pump which I believe is used to sense low fluid levels in the reservoir bottle.
Any and all feedback is very welcome.
Party Animal
Party Animal
