nixie clock example
Discussion in 'Electronic Basics' started by BrunoG, Jan 30, 2006.
  1. BrunoG
    BrunoG Guest
  2. Boris Mohar
    Boris Mohar Guest
    And if that doesn't work you can always download a desktop version
    http://www.sb-software.com/nixieclock/
    Regards,
    Boris Mohar
    Got Knock? - see:
    Viatrack Printed Circuit Designs (among other things) http://www.viatrack.ca
    void _-void-_ in the obvious place
  3. Cool. Could you tell me the duty cycle and period of the PWM for the
    170V switching power supply? Is the BTY20 part number correct? I
    believe that is an SCR, why isn't the gate connected to something? Can
    you recommend a substitute part number that is still in production?
  4. SioL
    SioL Guest
    Also found this:
    http://www.sb-software.com/politicalinvaders/
    Political Invaders is a game similar to space invaders, but rather than blasting aliens, you get to blast your favorite politicians,
    commentators, and politically slanted news reporters with pies. All the while you'll have to dodge the bombs they throw at you.
    Yep, there's Bush as well for us lefties.
  5. BrunoG
    BrunoG Guest
    Thanks !
    the duty cycle is 50%, frequency is around 40Khz.
    You are right, my mistake about the diode : it is a cheap BYT01/200 high
    voltage fast recovery diode, sorry !
    I will correct the schematic in a few hours.
    Bruno
    http://www.micro-examples.com/public/microex-navig/doc/150-p16f84-single-nixie-clock.html
