C
[email protected]
Have an OEM battery charger for mid-1980's equipment that does not
appear to be operating correctly. It has been longer than that since
my high school Physics' classes and I have exhausted my personal
"knowledge base" as to trying to diagnose and correct this "problem."
Any suggestions as to how to proceed will be appreciated.
Background:
The battery charger is marked as Input AC 120V, 50/60Hz, 5W
and Output of DC 10.43V 180 mA.
The Red LED for "operating" is not illuminating and the 3A fuse for
the equipment is blown.
Checked the battery charger secondary output at the connector and it
is reading 15.34 VDC with no load.
Main's current was 121.4 VAC
Opened the battery charger case. Transformer is marked as "206082" and
label logo appears to read as "SDB."
Secondary output side has three post. I will refer to them as L, C,
and R.
Voltage at L and C or at C and R is 13.74 VAC.
C feeds the lead to the equipment connector jack, the negative pole.
L and R each go to their individual diodes (can not read the values)
and then connect together. The voltage at either L or R to C, after
being rectified is 15.39 VDC.
The combined L & R then connects the lead to a 68 ohm resistor (which
feeds one side of the Red LED) and also into what I assume to be a
Ceramic Tubular Capacitor (light bluish colored, "dog-boned" shaped
with end leads and color banded Gold/blank/Gold/Gold/White(or
silver?))
Voltage across the two leads for the LED reads 0.000VDC.
The output lead of the "capacitor"? then feeds both the other lead of
the Red LED and continues as the Positive pole of the equipment
connector jack.
Questions:
1) Is the 15.37 VDC "no load" output at the connector representative
of a battery charger malfunction?
2) Is this a reason that the LED is not illuminating?
3) The OEM feels that this "simple" battery charger is worth US
$120.00. Any suggestions?
Again, thanks for any suggestions.
Background:
and R.
silver?))
connector jack.
Questions:
