Newbie question about 12Vdc fan
Discussion in 'General Electronics Discussion' started by tormod, Apr 5, 2015.
  1. tormod
    tormod
    Apr 5, 2015
  2. (*steve*)
    25,384
    2,771
    You need one that will physically fit, and have roughly the same flow rate (err on the side of greater flow).
    It must be a 12V fan, and the current drawn will probably be similar and acceptable if you follow this advice.
  3. tormod
    tormod
    Apr 5, 2015
    Thanks Steve - I've found similar 40mm fans that are 12V. What about things like ball vs sleeve bearings? I also notice that some fans have 2 wires, some have 3 and some have 4. Can a fan with 4 wires be modified so that it works with a 3 pin connector?
  4. Colin Mitchell
    Colin Mitchell
    1,417
    312
    Aug 31, 2014
    A ball-race is best. It must have the same number of wires or 2-wires will work with all arrangements.
  5. (*steve*)
    25,384
    2,771
    I'd probably go for fluid dynamic or magnetic bearings if they are available. Otherwise, as Colin has suggested, from the two alternatives you have given, ball bearings are better.
    And go for the same number of wires. As Colin also suggests, a 2 wire fan will work, but it will always run at full speed and will not offer ay speed feedback to the unit. This will at least cause it to be noisier, and may cause other problems.
  6. elebish
    elebish
    177
    12
    Aug 16, 2013
    If it has the same voltage and current ratings and moves air in the same direction as the old fan, it will probably work.
