newbie needs TV help
Discussion in 'Electronic Repair' started by Gomez Adams, Apr 29, 2005.
  1. Gomez Adams
    Gomez Adams Guest
    I have a Sony Trinitron Model KV-32S22. The color is off and I can'
    adjust it using the remote. Also it takes about 5 minutes for th
    picture to come on.
    A red light flashes timer until the picture comes on. Any advice
  2. kip
    kip Guest
    Sounds like Picture Tube is having a AKB problem.
    kip
  3. JANA
    JANA Guest
    I sounds like the CRT is having some problems, due to failing. It can be
    verified by taking the voltage readings, and waveforms at the pins, and
    comparing them to the specifications for your set.
    Since you are not in to doing TV service, I would suggest to take the set to
    a reputable shop and have it properly checked. This way you will know for
    sure what the fault is, and then be able to make an intelligent decision if
    you are going to want to have it serviced or not.
    JANA
    _____
    I have a Sony Trinitron Model KV-32S22. The color is off and I can't
    adjust it using the remote. Also it takes about 5 minutes for thw
    picture to come on.
    A red light flashes timer until the picture comes on. Any advice?
