Newbie needs advice
Discussion in '8bit Microcontrollers' started by Alan, Sep 16, 2005.
  1. Alan
    Alan Guest
    HI Guys i am new here and to PICS in general my history is in Power
    electronics rather than digital/ microprocessors but i have been asked to
    try to design a controller for my friend so thought it would be a good
    excuse to learn PIC programming.
    I have brought a couple of books and have been scanning the internet but i
    wondered if anyone could give me some pointers to some links that may help
    me with this project.
    The Project is to build a hand held controller for a large mechanical clock
    that i have got my hands on. it is addressed by RS422 2400 baud, 7 data
    bits, no parity, 2 stop bits. i have the data string as well somewhere.
    the controller will need a LCD display a newmeric keypad and three other
    butons.
    The display will show competitor number (three digits) and faults (2 digits)
    and also timing manual start but i would like to add an option latter of a
    triggered start.
    Which PIC would people reccomend
    can anyone point me at a few links or comments here please.
    Many Thanks
    Alan
  2. ChadMan
    ChadMan Guest
    MeLabs. Not free but was easy to get going right away on projects. M<elabs
    has decent email support. The picBasic forum is great!
    My first project pic controlled 110 VAC ignitor board for firing hand held
    torch/welding systems. Second project was an exerciser/tester to life
    cycle/reliability test the ignitor board. LCD readout: counts the square
    wave pulses and the 15KV spark pulses generated by the Pic on the ignitor
    board. cycled the ignitor board for over 50,000 tests reliably.
    Great forum for help: http://www.picbasic.co.uk/forum/
    Olympic timer posted here:
    http://www.picbasic.co.uk/forum/showthread.php?t=632
    Samples here: http://www.melabs.com/resources/samples.htm
    I'm relatively new to programming microcontrollers/electronics. I am looking
    at C for my next project. Never used it before. So it should be an
    adventure. I don't have time to learn assembly.
  3. Roger
    Roger Guest
    All depends on what you want to achieve in the end. Are you programming in
    assembler or C?. If programming in C then nows a good time to start using
    the PIC18F series as Microchip have provided a free student download for the
    C18 compiler (only optimisation limited after a certain number of days).
    Will you be designing your own board or are you looking for a pre-built
    board with as much of your required functionality as possible?.
    Also, if you aren't sure if you'll have enough code space to fit your design
    into, either choose a big part to start with or socket your micro. That way
    its easier to upgrade should you need to. I always use the biggest part I
    have and when the project is finished, drop in a part that more fits the
    bill.
    I have recently used the small pic boards at www.picmodules.com as it gets
    you up and running quickly and is easilly changeable. But if you want to do
    the whole project youself then maybie just stick with smaller DIP parts.
    My opinion. Go PIC18 for C (and get an ICD2 debugger from somewhere).
