M
Michael
I am fairly new to this and have several (simple) question:
I have a krypton flashlight bulb (markings on bulb say 4.8v .5A). The
original flashlight that the bulb was removed from used 4 AA batteries.
1. Wouldn't the 6v from the batteries be 'pushing' the bulb a bit and
reducing its life?
2. If I want to wall-wart power this bulb, what voltage wall wart would be
recommended?
3. Since most wall warts (unregulated) supply higher voltage than the
sticker says, what method
should I use to bring down the voltage to the recommended voltage
(regulator, resistor, etc)
(I remember once trying to do something similar to this project and using a
resistor. Even
though the resistor was a high wattage resistor it got REALLY hot)
4. I think this question probably will have the same answer as #3, but if I
want to dim the bulb what
method would be recommended?
Thanks for you assistance
reducing its life?
recommended?
resistor. Even
