Newbi & Pic Possibility
Discussion in 'Electronic Basics' started by Newbie!, Jan 27, 2004.
  1. Newbie!
    Newbie! Guest
    Hi Group,
    Im looking at a Project to keep me out of trouble on a night <Grin>. Heres
    what I would like to do:
    Firstly to learn about Pic Programming and hopefully use this to:
    Build a Project which will have either a Cat5 Network Connection and a Web
    Browser on it, or a Serial interface to connect to a PC, This will Monitor
    in 3 Rooms, the Temeratures and if there has been a Loss of Power. If the
    Temperature gets to Hot or To cold, or if there was a loss of power My
    project would either Ring a Mobile and a voice would say what condition we
    had, or send a SMS. Idelly a Small LCD display in each room would tell me
    the Temperature.
    I would also like to be able to Monitor the Temperature and Power from A PC
    Serial
    Connection or Web Browser in real time, with graphs
    I Know the basics about Electronics and am also an intermediate programmer,
    with Visual Basic.Net
    I don`t have any worries about learning new things!
    Any Links or advise would be appriciated
    Many Thanks
    Si
  2. Tim Dicus
    Tim Dicus Guest
    Hi Newbie!
    It may be a little more than you want to spend initially, but take a look at the RabbitCore RCM2200.
    http://www.rabbitsemiconductor.com/products/rcm2200/index.shtml
    Has an Ethernet card onboard and includes a TCP/IP library. VERY SIMPLE to use! Take a look at some of the examples in
    "Introduction to TCP/IP". Lots of program and data memory. Lots of I/O. Fast (22MHz).
    It is about $239 for the development kit. You only need one of these!
    http://dkc3.digikey.com/PDF/T041/0297.pdf
    Includes the programmer, Dynamic-C compiler, and prototye board.
    After that, the boards are $55 each at Digi-Key (www.digikey.com). To me, just the savings in development and programming time make
    it a true bargain!
    Just an alternative...
    Tim
  3. For the Ethernet connection, I have used the X-Port connected to the PIC
    serial port.
    Many PICs have serial ports which can be level shifted up to RS-232
    compatable
    with your PC Serial port.
    Easilly done with the A-D ports in a PIC...
    Also easy via a digital port.
    So you are now proposing a PIC per room...
    A visual basic solution on the PC.
  4. Merlin
    Merlin Guest
    Thnaks for your reply, in answer to your questions (Yes), tho im a lost as
    to where to start?
    What Pic Programmer would you think i would need? What Software and PIC
    chip?
    Could I use a VB program and interface to the Pic on the Project via maybe a
    IP address?
    What would I use if I wanted to upload a HTML web page to my project to
    control it?
    I`ve got loads of time available so learning is not a problem.
    Many Thanks
    Si
