zeroweaver
- May 9, 2014
- 1
- Joined
- May 9, 2014
- Messages
- 1
My boss asked if I could find a way to prevent damage to our shrink wrapper that is missing some components. It used to have some kind of limit switches a long time ago but not anymore. The way it works now is you put a pallet on the platform and attach the shrink wrap. Then start the pallet spinning and you manually work the switch that moves the shrink wrap bar up/down. In the pic of the control box the switch labeled "A" is the on/off switch for the pallet spinner. The one labeled "B" is the switch that operates the shrink wrap bar. It is a threeway toggle switch with a "ratchet?" stop between the two directions so you can't switch it from one direction to the other in one motion. You have to stop in the middle before you can switch it the other way. This was it gives the heavy geared motor a moment to stop before going the other direction so it doesn't strip the gears. The way its setup now if the person is not paying attention they can run the wrapper bar off the top or run it to the very bottom freezing up the gearbox. I need some kind of limit switches on the top and the bottom that will prevent someone from going to far in either direction. I was thinking it should be very simple and cheap to rig something up. I dont really know how to design this. Please help. Thanks See pics
