New RCA TV
B
Brian
I have a new RCA TV. It was made less than a year ago and is great. However,
as RCA's are suspect to, and I've asked and they confirmed, it's normal for
the TV to take a while to turn on (10 seconds) and to have a delay in
changing channels (2-3 seconds).
Would there be a service menu option to atleast shorten the delay when I am
changing channels and I get a picture quicker?
Aloha
Brian
B
Brian
The model is 27R411T.
The chassis is ITC008FHM.
C
Charles Schuler
However, as RCA's are suspect to, and I've asked and they confirmed, it's
normal for the TV to take a while to turn on (10 seconds) and to have a
delay in changing channels (2-3 seconds).
CRTs need a warm-up time. Some sets apply reduced filament voltage to the
CRT (when the set is off) to shorten this time. I guess your RCA is one
that does not. Actually, I prefer the way yours is designed. 10 seconds is
no big deal.
A
Art
Channel change delay, are you using a cable box, or a satellite receiver?
Check your cable select setting if your are using direct cable hookup.
Maholo!
B
Brian
Hi. Not using satellite or digital cable. Just standard cable. We've three
other TVs here and none have this issue; seems it's an RCA 'feature' as they
have confirmed when I asked about it via email.
I was hoping there might be a service menu to reduce or limit this.
Brian
