L
Luhan Monat
That gives me an idea. Mount a 433mhz transmitter in a battery operatedKlaus said:One of those projects I never got to (perhaps in 2010):
Build a battery operated probe that captures via a highspeed ADC the
waveform and stores it. The probe has high-speed optocoupler syncronization
with the probe no. 2, so that a level trigger on one of the probes will
start the acquisition at both probes at precisely the same time. When done -
transfer the signal digitally to a PC for processing (sum, difference or
multiplication of the two channels)
Downside is that it is not realtime :-(
Cheers
Klaus
probe; connected a 433mhz receiver to the scope. This is good to over
5khz with the cheap units. Range can be up to 100 feet so you can make
measurements around the lab without hauling the scope around.
