John Tserkezis wrote
Wrong when its designed in to the device right from the start.
Yes, even when it's designed right in from the start. Do you want
to change the habit of a lifetime and start _justifying_ your
pronouncements instead of simply endlessly repeating them as if
that alone is enough to make them true?
Yes, even when it's designed into the device right at the start.
Not that it really matters, this kind of circuitry is basically
invisible to the rest of the system aside from any voltage drop.
You can put it in at the start or before laying out the final
production board - it doesn't make that much difference
Have fun explaining the led thats included anyway etc.
Because a cost/benefit analysis (however informal) shows that LED
is worth including. It's a standard design trade off, cost vs.
functionality. For some devices, those indicator LEDs are the
_only_ sign of life that is not dependent on connected equipment.
Thanks for that completely superfluous proof of why no one is
actually stupid enough to employ you to design anything that matters.
It was more of a proof than simply spouting "not when it's designed
in right at the start" in parrot-like fashion. The way I'd do this
would use four transistors and four resistors, plus a bit of board
space, extra soldering, possibly extra drilling, more faults etc.
I don't see it costing much less than about 8p even with a reasonable
production run. For some sectors that is unacceptable even on
equipment going for three figures. If the device is supposed to
sell for a fiver it is unacceptable anywhere.
