T
The Real Chris
If you make a single loop of wire bent into a circle and pass a regulated 1
amp current through it you will make a "magnetic field". According to Gauss
you have to imagine it is there and calculate accordingly. Then comes an
extraordinary performance of human intellect beginning with the magnetic
shells construction that shows that the field is uniform across the plane of
the loop.
According to Carl Popper we should now measure it to see.
Using a compass as a tangent galvanometer with the earth's field as a
reference you can measure the relative strength of the field in the region
of the magnet by measuring its deflection (according to the field theory). I
have done this and the field is about three times higher near the wire than
at the centre. This disproves the magnetic shell construction.
Another basic algorithm is the idea that a series of loops is like one loop
multiplied. Well if you do the same thing for six turns then the compass
measurement is the same near the wire than at the centre.
This shows that the basic algorithm of what is true on one is true of many
as one times the number of repetitions, is false.
I would like to propose a different model: that the magnet is responding to
spin-spin interactions as a quantum mechanical effect. These are entirely
electrostatic in nature.
The magnetic field does not exist it is fictitious.
The model of the magnetic effect of current is in reality the Lorenz
contraction of the moving electrons relative to the fixed charges in the
wire and the electrostatic force is mediated by virtual photons.
Since the electrons always occupy the same space in the wire even though
they are moving it shows that special relativity is an effect like
perspective.
The inductive effect is in reality caused by the acceleration of electrons.
Now these little charged particles are governed by quantum mechanics and the
energy states up the ladder are discontinuous and the electrons jump from
one state to the next the two states overlap and during the transition a
fluctuation occurs and a photon emission occurs, just like the hydrogen
spectrum.
This photon interacts with just one electron in another wire or the same
wire and imparts momentum and energy to change the electron from its
original state to its new state. This also means that the photon carries
momentum both linear and angular and energy.
This is both mutual and self inductance.
Chris
the loop.
perspective.
spectrum.
Chris
