New Form of Power Generation
D
Danno
This was sent to me by a pal, but I have been unable to confirm the story (on
the internet).
What a beautiful solar day!
EDMONTON (CP) - A University of Alberta research team says it has
discovered a clean way of generating electricity by simply directing
water at a solid surface.
The discovery is chronicled in a research paper to be published Monday
by the London-based Institute of Physics. It has a wide range of
possible uses - from powering small devices such as Palm Pilots or
calculators with water batteries, to maybe someday contributing
electricity from a clean, renewable source to a national power grid,
says the university.
"The discovery of an entirely new way of producing power is an
incredible, fundamental research breakthrough that occurs only once in
a lifetime," said David Lynch, dean of the university's engineering
faculty.
"This groundbreaking discovery will earn these researchers and the
University of Alberta a place of prominence in scientific journals and
textbooks for decades to come, and may find significant applications in
numerous commercial areas."
With the help of two graduate students, engineering professors Daniel
Kwok and Larry Kostiuk were able to light a small bulb by squeezing a
syringe of ordinary tap water through a glass "filter" with
microscopic-sized holes.
They did it by harnessing the natural energy that is created on a very
tiny scale when a flowing liquid meets a solid surface.
Their research has been published in the physics institute's Journal of
Micromechanics and Microengineering.
Kostiuk, chairman of the mechanical engineering department, said a
conversation between him and Kwok led to the eureka moment and their
invention.
He said Kwok - a scientist who studies the properties of the first few
molecular and atomic layers on surfaces - was explaining his work to
him.
It's been known for many decades that when a liquid such as water comes
into contact with a non-conducting solid such as glass, ceramic or
stone an interaction occurs between the two at a microscopic level
that creates a charge on the surface, Kostiuk said.
Because of the movement of positive and negative ions, the solid
becomes negatively charged and the water next to the surface
positively charged.
Kwok was explaining if one puts the water through a "microchannel," -
imagine a tiny tube - the positive and negatives ions move so that one
end becomes positive and the other negative.
"I asked him ... couldn't we exploit that to create electricity,"
Kostiuk said.
Kostiuk was surprised by his response - that it was possible but it
hadn't been done before. In his turn, Kwok was surprised by the idea.
"It doesn't happen very often. That moment when you understand is a
very positive thing to feel," said Kostiuk.
"I was walking on a cloud for the next day. I couldn't believe nobody
else had really looked at this and done it before.
"The possibility just kept bouncing through my mind about how we would
do this," he said, adding Kwok shared his enthusiasm.
But it was a blend of being excited and cautious. It took patience to
wait until they were able to take their theory and calculations and do
an experiment to show it was real.
What continues to strike Kostiuk is the simplicity of their invention.
Using a syringe, they pressed water through their "filter," a two-
centimetre glass disc with 450,000 holes in it - something commonly
found in labs, he said. The holes act as the microchannels where the
charge is created.
They attached metal electrodes at either end of their device and
connected them using a wire to create a pathway for the current - and
they had electricity.
"Embarrassingly, that's it," he said.
This is only the starting point and much work needs to be done to find
ways to develop applications, he stressed.
But conceivably, a version of their battery using pressurized water
could be used in small electronic devices in a number of years. But
you'd have to "recharge" your cell-phone battery by using a hand pump
to repressurize the water, for example, Kostiuk said.
Theoretically, there's nothing to prevent it from being scaled up,
Kostiuk said. To create electricity on a very large scale, you would
have to have a large volume of water flowing through many million
microchannels.
The university applied for a patent on their invention in August and is
currently working with the inventors to find ways to commercialize the
discovery.
<A9> The Canadian Press, 2003
D
dt
the internet).
http://tinyurl.com/rktc
"The source of that energy is the work done to push the liquid through
the channel."
You still gotta push, pump, or get the water pressure.
DT
D
daestrom
good point. i suppose that would just make it an alternative to the
existing turbines used at hydro plants ?
Yes. No energy for 'free', but a novel storage instead of traditional
batteries. Would be interesting to know how its overall efficiency rates
and the energy density of it.
daestrom
the channel."
DT
yes or otherwise it would fall into the perpetual motion or energy
criteria. If it is true, this is no problem, and any circumstance
suitable for a water turbine running a generator, might also be
suitable for setting up direct conversion to electricity.
W
William P.N. Smith
Storing water under pressure in your cellphone? Hardly seems
practical...
I
Ian Stirling
Not really.
I'd be very very surprised if the turbines don't extract well over 90% of
the waters energy.
This is well under 1% efficiant, and it'll rapidly clog.
S
Steve Spence
maybe it will come with a hose you hookup to your water faucet. The computer
industry will have to come up with an acronym for that. USB is taken, how
about YAW (yer all wet). "Run down to the store and get me a YAW cable
B
Bob Adkins
They're in no way saying it's free electricity. It's just another means of
creating and possibly harnessing electricity with energy input.
I can already foresee problems, however. I bet salts or solids in the water
would have a dramatic effect on the process, rendering it a lab curiosity or
small scale only.
D
daestrom
practical...
Agreed. I was just thinking of it as an alternative way of storing energy.
Wondered how it would compare with other storage techniques.
daestrom
small scale only.
I have no idea what I'm talking about :)
That said, I imagine that highly purified water in a contained system
would continue to provide power (in whatever amounts this device can
produce) as long as you are pumping the water through it. The filter
should not clog because the water is recirculated. From my reading
of the original post it's the movement of water through the holes that
strips electrons from one side and deposits them on the other.
Maybe this can be used in some way to capture kinetic energy in small
amounts from shoe soles or other things that tend to sway in the breeze.
Liek many other inventions, now they just have to find an application that
needs it.
Daniel
