S
SDL
MERLINO BOARD EMBEDDED SYSTEM.
Flexible, reliable reconfigurable.
The only limit to its application is only that of your imagination.
How many times has your PC failed to boot because it is blocked by a prosaic
problem?
How many times have you had to reset a PC which has frozen at the most
inconvenient moment?
How many difficulties have you had to overcome to adapt your PC with the
operative system, to make it carry out duties for which it was not
conceived.
Why use personal computer components to realise your Embedded application
when you could reach your objective more easily?
Thanks to "Merlin Board", today you can realise an Embedded System which is
reliable, safe, economic and personalised for your application. You will
finally be able to guarantee your customers a production which is constant
over time and that is not subject to the problems related to the continuous
updating of hardware which is so typical in the PC world.
"Merlin Board" is an extremely innovative product
Its matchless flexibility comes from the fact that it is equipped with a
completely FPGA based architecture. On the "Merlin Board", you will not find
the usual microprocessor, but a soft-core processor synthesised inside the
FPGA, together with a range of other elements which make up the architecture
of the board.
What is today defined as SoPC (system-on-a-programmable-chip).
This solution makes it possible to overcome traditional limits of
architecture, and go as far as implementing on the core of the processor a
set of personalised Assembler instructions, which saves on many clock cycles
compared to the traditional approach.
Avant-garde technology as an answer to all Embedded System problems.
The start-up of software after a black-out.
The FRAM memories have similar characteristics to the SRAM ones, they have
low access times both in writing and reading, with the advantage of
maintaining the data in memory even during power failures.
By using this interesting feature of FRAM, the "Merlin Board" elegantly
resolves the problem of the start-up of programmes which are running on the
board, after a power black-out. It will then be possible to restart the
software from the exact point it was interrupted.
MAIN Features
Power:
Single voltage of 12V also not stabilised
Video Section:
Optimised for the viewing of vide-graphic animation.
VGA CRT/LCD output configurable with resolutions up to 1024x768.
Video output RGB 15/25 Khz with resolutions of 320x240 and 420x240.
All supported resolutions handle 65000 colours.
Management of the Alpha Blending function (transparency of the viewed
graphic objects).
In order to lighten the work load of the processor a function has been
installed on the hardware which makes it possible to superimpose two images
and calculate the result point by point according to the "alpha" colour
which determines the transparency.
Web Server:
TCP/IP interface on board, operates as a web server.
Audio Section:
16 bit stereo audio with 10+10W audio amplifier.
Input/Output:
16 lines for digital input and 16 lines for output with a power driver.
All the I/O are protected from eventual radio-electrical disturbances.
User Data Memory:
64 MB of Flash Memory (Intel Strata Flash) - Expandable.
Serial BUS:
1 port for 12C Bus to which it is possible to connect up to 255 peripherals
2 RS232 ports - Output for CC_TALK Bus
Clock System
Real Time Clock with backup battery - Watch Dog Timer
Non Volatile Memory
256K FRAM (ferroelectric memory)
Safety
Implementation of an architecture which reasonably protects from eventual
violation both of the software and hardware.
Optional Modules available:
Module for GSM-GPRS connections - GPS reception module
USB Interface module - Bluetooth interface module
Touch Screen module
Case:
The "Merlin Board" is available in an plastic box equipped with a support
which may be used to attach it to the wall.
For more information on our services
and products, come visit us at
www.seventech.it
problem?
conceived.
of the board.
MAIN Features
Power:
Video Section:
graphic objects).
Web Server:
Audio Section:
Input/Output:
User Data Memory:
Serial BUS:
Clock System
Non Volatile Memory
Safety
Touch Screen module
Case:
www.seventech.it
