D
D Yuniskis
I often need to plug something in to the network temporarily
(e.g., to configure something or talk to a NAS box, etc.).
I have a switch in the office to serve the dozen or so nodes
there. So, there is always a spare port that I can use.
But, it's on the floor amid a tangle of power cords, network
cables, etc. I.e., I have to get out of my chair and *kneel*
on the floor to make the connection.
My knees don't like it when I do this. They go to great
pains to remind me of their displeasure!
I have these little "surface mount" (as in "surface of the wall")
boxes that are intended as four point drops. I.e., you feed
four cables into them "from behind" and have four connectors
available on the face of the box. Much like a wall plate
but this will mount *on* the wall instead of flush.
I had thought of installing three connectors in the box. Then
wiring connector 1 to connector 2 "straight thru" and then
chaining on connector 3 "with a twist". After mounting this
on the underside of one of the desktops, I could connect
connector 1 to the switch "permanently" with a standard patch
cord.
Connector 2 would give me a convenient "outlet" to which other
devices could be attached, temporarily. And, in those cases
where I need to connect "node to node", I could use connector
1 (or 2) with connector 3 (to get the "twist") without the need
of a crossover cable. I.e., I can keep one "regular" patch
cord handy and use it for all needs.
Neglecting the problems with trying to get two wires on
a single punchdown block... am I likely to have other
problems from the impedance bump that the "extra" connector
will present? Or, will it be insignificant enough (especially
since this is just a temporary connection, normally)?
Thx,
--don
cord.
Thx,
--don
