Netlist Comparison
Discussion in 'CAD' started by Jim Thompson, Jul 16, 2005.
  1. Jim Thompson
    Jim Thompson Guest
    Anyone know of a reasonably priced netlist comparator?
    What I'm looking for would be able to read in two netlists and
    generate a report of mismatches.
    ...Jim Thompson
  2. Jim,
    I think you're asking for something that can actaully
    parse the netlist and understand it.
    However, I just use text compares, like a UNIX style
    diff(you can run it as part of cygwin on a PC) or
    Windows WINDIFF.EXE. It doesn't "read" the netlist
    in that it doesn't understand the topology of the
    netlist'ed circuit, but if two netlists were generated
    with the same tools, then it's very effective.
    --Mike
  3. Jim Thompson
    Jim Thompson Guest
    Netlists generated on two different tools, so a text-compare won't
    work :-(
    Has to be something like an LVS checker, but not tied to the layout
    tool.
    ...Jim Thompson
  4. xray
    xray Guest
    If I understand correctly, a standard text-based line compare tool won't
    work because it reports differences that don't matter to you?
    If so, can you give me an example of two lines that are different, but
    you want to be treated as the same? Or, if I missed the point, the kinds
    of things that need to be different from a line compare tool.
    I was just googling and found:
    http://winmerge.sourceforge.net/
    Seems more powerful than windiff, and has some configurable features,
    but not sure if it could be trained to do what you want.
  5. Ken Smith
    Ken Smith Guest
    What format are the net lists? Did the references change from one version
    to the next or is it only the net names and some interconnections?
    Where I work we use a perl script to compare net lists in the PADS2K
    format. It almost works right.
  6. Jim Thompson
    Jim Thompson Guest
    The trouble is that two netlisters will name devices differently and
    number nodes differently.
    So a netlist comparator must travel in from I/O in each netlist and
    match connectivity and device sizes, not naming convention.
    So an ordinary text compare won't work.
    ...Jim Thompson
  7. Robert
    Robert Guest
    These people:
    http://www.iceditors.com/products/products.html
    do a PC layout tool and a DRC and a NLE (Netlist Extractor tool) that works
    with their LVS Tool.
    Their site seems to say it can compare netlists when it claims:
    " LVS program compares netlists: LVL, SVS, and LVS "
    where the "SVS" seems to mean "Schematic vs Schematic".
    They also say:
    " Accepts schematic netlists in CDL, SPICE, PSPICE, and HSPICE dialects "
    May be what you want but it may only compare netlists from two instances of
    the same tool.
    Robert
  8. Jim Thompson
    Jim Thompson Guest
    Thanks for the lead. I'll check into it.
    ...Jim Thompson
  9. Robert
    Robert Guest
    You're welcome. Let me know what you find out. I used their Layout, DRC, and
    LVS tools. But I never had reason to poke into these capabilities if they
    had them at the time.
    Robert
