Neon lamp for turntable repair
Foghorns
May 7, 2016
3
May 7, 2016
3
Does anyone know where I can get a suitable replacement for one of these?
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
That does not look like the original.
You can get very powerful leds which could be supplied from a low voltage winding if you cannot get the original neon.
Alec_t
Jul 7, 2015
3,590
Jul 7, 2015
3,590
That neon is connected directly to mains voltage if the transformer has the D-type strapping. Having it's terminal(s) exposed as shown in the pic is potentially dangerous.
Safer to use LED illumination as duke37 says. A pair of back-to-back LEDs (with suitable current-limiting resistor) could connect to terminals 2 and 3 of the power supply.
Foghorns
May 7, 2016
3
May 7, 2016
3
Thanks for the warning.
I am a complete novice although I have repaired a few things here and there where i have been given specific instructions as to what to change (capacitors and resistors etc...).
I'm not using the turntable like this, It normaly has a cover over the lamp which i removed for the purpose of the photo.
I have read that the LEDs aren't quite as good because they don't flash on and off as well!?
Alec_t
Jul 7, 2015
3,590
Jul 7, 2015
3,590
Depends how the LEDs are used. If driven by just the rectified AC they will fade in and out rather than flash briefly.
They can easily be made to flash, however, with a simple circuit like this:-
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
I would think that if they were fed with a fairly high voltage which was backed off with a zener so that only the peak voltage was used, they would be quite good.
Could Alec do a simulation?
Alec_t
Jul 7, 2015
3,590
Jul 7, 2015
3,590
As requested :-
This shows two alternatives.
The 'fairly high voltage' duke37 mentions is 10VRMS AC in the sim, since going by the 16V rating of C901 in the power supply, that's what I guess the transformer secondary outputs.
73's de Edd
Aug 21, 2015
3,622
Aug 21, 2015
3,622
Sir Foghorns . . . . . . .
Possibly . . . .
Looks like this might be the definitive replacement for that lamp.
Note that the electrodes are designed for a spot production of illumination, then the lens built into the end
of the envelope , provides for even further spot concentration.
It may be a bit pricey, as being compared to a wire leaded common NE-2 (wide lateral/spatial light dispersion) but considering a neon lamps l o o o o o o o o o long life, that would be my choice in a neon replacement.
Plus you want to confirm that present R901 series limiting resistor value is not being too low for this lamp, if the light initially shows up to be excessively bright..
Reference:
http://www.conrad.com/ce/en/product/582852/Barthelme-00012340-Neon-Bulb-230-V-03-W-15-mA-BaseE10-Clear
Bulb NOT to scale:
73's de Edd
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
Hi guys,
A note:
The neon light in the turntable is used for stroboscopic adjustment of the plate's speed.
The neon light will "flash" twice in each cycle (both on positive and negative parts),the "bumps" on the plate rim are made in accordance with that.
Here is a circuit that can replace the neon lamp with 3 LEDs,
a bridge rectifier and a resistor.
It will tap into the bridge on the secondary (around 12V peak AC).
Use a small rectifier bridge, 3 high brightness 5mm blue color 2mA (or 10ma) LEDs.
for 2ma Blue LEDs use R=1.5K resistor.
For mounting the LEDs should be glued together.
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
Alternatively, use another string of leds connected in inverse across dorke's string. Then the rectifier will not be needed.
Foghorns
May 7, 2016
3
May 7, 2016
3
Thanks everyone for your very interesting and informative help. However, I'm mostly liking the look of 73's de Edds Neon. I think this would be the easiest solution for me plus it looks like it would fit perfectly into it's housing.
Am i right in thinking that i should just be able to snip the wires off the old then just directly solder the new one on?
i.e: it's the correct voltage and ampage rating? ( I said i was novice)
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
You can solder the wires.
There are 2 problems with that solution.
1. There are so many different Neon lamps with different voltages/currents and light brightness,since you don't know what is the part you have it may or may-not be the correct part.
2. The lamp body(and bayonet) will be connected to mains so you have to isolate them properly!
Similar threads
Replies
4
Views
2K
JohnR66
S
Replies
13
Views
10K
Rich Grise
R
D
Replies
3
Views
2K
Daniel J. Stern
D
