Neither parallel nor series
Discussion in 'Electronic Basics' started by Wong, Oct 20, 2004.
  1. Wong
    Wong Guest
    What theorem or method can be applied to calculate the total
    resistance at point A to B?
    ----- A -----
    R1 R2
    ------R3------
    R4 R5
    ----- B -----
    Thanks.
  2. burbeck
    burbeck Guest
  3. Jack// ani
    Jack// ani Guest
    Star to delta conversion will work here.
    Your above star connection can be converted into equivalent delta
    connection, like this
    RB
    ___
    |--------------|---|___|----------------|
    B RA | | | | RC A
    | ___ | | ___ |
    |----|___|-----|-----------|-----|___|--|
    R5 R2
    created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
    RA = ( R4*R1 + R1*R3 + R3*R4 ) / R1
    RB = ( R4*R1 + R1*R3 + R3*R4 ) / R3
    RC = ( R4*R1 + R1*R3 + R3*R4 ) / R4
    Now it is easy enough, for you to further simply it.
  4. KM
    KM Guest
    Use Delta to STAR conversion,
    the result became, and it is series with parallel series.
    A > | | |
    Ra = (R1+R2)/(R1+R2+R3)
    Rb = (R1+R3)/(R1+R2+R3)
    Ra = (R2+R3)/(R1+R2+R3)
    it is in Electrical technology by Edward Hughes
    KM
  5. Wong
    Wong Guest
    I think there is a correction here, Ra should equal to
    (R1*R2)/(R1+R2+R3) and Rb, Rc as well.
    So the total resistance is (Ra + ((R4+Rb) || (R5+Rc)))
    Let say, R1=1k, R2=2k, R3=3k, R4=4k and R5=5k. I will get the answer
    of 2.9k and it is same with my simulation. Thanks !!
  6. Jack// ani
    Jack// ani Guest
    whoops, what an ugly mistake i did; feeling very shameful.
    should be delta to star. really frustrating isn't it……should go and die somewhere.
  7. If that is the biggest mistake you make this year, you are doing
    better than most of us.
  8. Jack// ani
    Jack// ani Guest
    well i hope so.
    thanks
  9. You forgot to say "I don't like doing my own homework, please
    do it for me."
    And the correlary: if this ISN'T a homework problem, you
    should say so. It also would help if you mentioned what
    you've tried so far, and whether you're an absolute beginner
    or not.
  10. Bill Bowden
    Bill Bowden Guest
    I'm not following these formulas.
    If all the resistors R1-R5 are 1 ohm, then the
    total resistance from a to b will be 1 ohm.
    But, according to the formulas, Ra, Rb ,Rc will
    be 2/3 or 0.67 ohms. So, we have 1.67 in parallel
    with 1.67 which is 0.83 which is in series with
    Ra (0.67). That all adds up to 1.5 ohms, but it
    should be 1 ohm.
    What am I missing?
    -Bill
  11. Don Kelly
    Don Kelly Guest
    Nothing:
    The formula is wrong for delta to star conversion- try Ra=(R1*R2)/(R1
    +R2+R3) etc
    This will give you 1 ohm.
    In the case where R1/R4 =R2/R5, you can simply remove R3 as it won't have
    any effect. (figure out why).
  12. Rich Grise
    Rich Grise Guest
    Because the current's flowing both ways simultaneously, and so, from the
    POV of our perceptive systems, cancel each other out and so don't exist.
    Cheers!
    Rich
  13. John Fields
    John Fields Guest
    Puh-leeze...
    If R1/R4 = R2/R5, then the voltages at the junctions of R1R4 and R2R5
    will be equal, and with no potential difference across R3 current
    can't flow through it, whether it's an open, a short, or anything in
    between.
    As a matter of fact that's why, at null, the detector across a
    Wheatstone bridge vanishes.
