Negative Spike Voltage
Discussion in 'General Electronics Discussion' started by Kurte Moyo, Dec 28, 2015.
  1. Kurte Moyo
    Kurte Moyo
    4
    Dec 28, 2015
    Hello there! I am doing my thesis today and I want to know if what circuit is suitable for filtering the negative spike voltage. Out thesis is regarding the Sudden acceleration of the vehicles, and one cause of it is the negative spike voltage entering the A/D Converter. We want to design a circuit that will filter / neglect the negative spike voltage coming from the battery and the sensors. We are also open to any suggestion that will help us regarding our topics. Thank you and God bless!!
  2. BobK
    7,682
    1,688
    Really? I thought the research indicated that sudden acceleration was generally caused by a driver hitting the accelerator when they thought they were hitting the brake. Can you link to anything that says it is negative voltage spikes?
    CDRIVE and hevans1944 like this.
  3. GPG
    GPG
    452
    66
    Sep 18, 2015
    What kind of vehicle? Electric? So many questions, so little information.
  4. Alec_t
    Alec_t
    2,982
    807
    Jul 7, 2015
    You could perhaps use a series resistor and Schottky diode to clamp the A/D input to within ~0.3V of the ground rail.
  5. Kurte Moyo
    Kurte Moyo
    4
    Dec 28, 2015
    Sir Bob according to the article " A more Detailed Electronic Mechanism for SUA" of Ronald A. Belt he said that "
    Sudden acceleration has been observed in all makes and models of automobiles having electronic
    throttles. This includes hybrid electric vehicles, which have an internal combustion engine (ICE) that
    uses an electronic throttle. The author has developed an electronic theory of sudden acceleration which
    explains the cause of sudden acceleration in all vehicles having electronic throttles
    . The cause is attributed to a negative voltage spike which upsets the control system for the electronic throttle, resulting
    in a wide open throttle."
    the negative voltage spike coming from the battery or from the sensors when sampled by the A/D Converter, it causes malfunctioning of the ECU and the desired output is wrong.
  6. Kurte Moyo
    Kurte Moyo
    4
    Dec 28, 2015
    automatic transmission vehicles sir. The data or information gathered by the Engine Control Unit is wrong when there is a negative voltage spike from the battery or from different sensors.
  7. Kurte Moyo
    Kurte Moyo
    4
    Dec 28, 2015
    Sir Alec, I will connect it before the A/D converter of the ECU? if there are multiple input from different sensors can I filter also the voltages coming from the sensors just only one Clamp Circuit or in every sensor input one Clamp circuit ? thank you so much sir]
  8. Alec_t
    Alec_t
    2,982
    807
    Jul 7, 2015
    If your ADC has multiple inputs you will need a respective clamp circuit for each one.
  9. BobK
    7,682
    1,688
    In all makes and models, which use different software and hardware? Not likely.
    Stupid people who press the wrong pedal is still the best explanation of "sudden acceleration".
    Martaine2005 likes this.
  10. CDRIVE
    4,960
    652
    May 8, 2012
    Hey Bob! I love a guy that has convictions and sticks to them. Here in S. Florida the term "Drive Through" takes on a whole new meaning. Cinder Block walls are little protection. Reinforced Concrete is the only barrier that stops them! Even then it's little protection for some that must get to the front of the Early Bird line.:p
    RE.. ECU spike protection: Don't all ECU equipped vehicles already have spike protection? Hell, an automobile is a portable EMI / RFI and electrostatic generator!:eek:
    Chris
