Needing Help To Identify a Diode !
Discussion in 'Datasheets, Manuals and Component Identification' started by Crossfade25, May 1, 2015.
  1. Crossfade25
    Crossfade25
    May 1, 2015
    I'm repairing a Orbits Digital Timer ! I found that 2 of the Through Hole Barrel Shaped Capacitors were bad !
    So I ordered new ones from DigiKey, One is a 25V 2200uF M Series, The other is a 6.3V 1000uF M Series, I got them both installed but when I switched the timer on I got nothing !! So I got my meter out and started testing ! I set my meter to the diode setting and I found a Zener Diode that's reading 0.098 in both directions !! Which is not good so here's my problem !! The only marking on this diode is PHC24 I need to find the spec's on this diode so I can find a replacement !!
    This digital timer uses 2 AA's so it runs on 3V's
    image.jpg image.jpg Here is a photo of the timer and the diode that was bad
  2. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    1.3W 24 Volt zener.
    Adam
  3. Crossfade25
    Crossfade25
    May 1, 2015
    Thanks Bud !! I Realy Appreciate The Help & The Speedy Reply !!
