R
Razzel
Built a slot switch to feed into the soundcard. It is intended to
calculate the period of a pendulum. 1) IT WORKS. but not well enough.
When the beam is blocked by a 1/4 in. wide barrier (in the 1 in slot) my
returned values are a couple in the low 120's, then jump to a run of 4-5
130's then back to 119 or 122 before jumping again to 130's. The
unblocked values are all over the place. 94, 61, 140, 210, 190, 88, 60,
60, 138, 218, ...
Nothing is hot. Its running off of a wall wart which is 9.12v unloaded.
I would expect if it is the wall wart problem then both sets of values
would vary similarly.
Both the LED (super bright) and the photoreceiver transistor (R/S
276-145) are fed from this source.
Any ideas why the values are out of whack???
I can show the circuit if needed but hopefully someone has a similar
experience. I think it must be CJD !
Raz
60, 138, 218, ...
Raz
