need some help picking out a Oscilloscope
Discussion in 'General Electronics Discussion' started by imjeffd, Jul 1, 2013.
  1. imjeffd
    imjeffd
    12
    Jun 4, 2013
    ok so I need a Oscilloscope I am thinking this one would work good
    http://www.hantek.com/english/produce_list.asp?unid=62
    but I have some questions im assuming that these has a max voltage but I don't know what it is could I probe a 110v outlet with this?
    I dont plain on using it for any frequency higher then 1MHz on something like a square wave
    but I don't know what bandwidth is for sure is that how hi of a frequency it can measure
    I also was looking at this one as well it seems a lot better
    http://www.amazon.com/PDS5022T-Port...8&qid=1372662494&sr=8-1&keywords=Oscilloscope
    im not sure what it is I need to know when piking an Oscilloscope out any advise or suggestions are welcome
  2. GreenGiant
    GreenGiant
    842
    6
    Feb 9, 2012
    The first one that you have linked is purely USB, that means you need to connect it to a computer and that will be the screen for the O-scope.
    The bandwidth is just the range that the scope can read, so that one can read 0-40MHz, and the second 0-25MHz.
    The voltages that it can read are dependant upon the test leads and the voltage ranges that it has, most will go to 5/10/25V per division with 5 divisions per side of the axis, so its max with a standard test lead would be 25/50/125V peak, but with a 10X test lead you can muliply those numbers by 10, a 100X by 100 etc (usually the test lead will have a max voltage it can handle)
  3. NuLED
    NuLED
    294
    Jan 7, 2012
    Rigol DS1052E / DS1102E has been often mentioned as an excellent deal, on various web pages and blogs I've read.
  4. Andre Gopee
    Andre Gopee
    35
    Sep 12, 2012
    Try this site http://www.saelig.com/PSBEB100/PSBEB100005.htm. I recently bought one of these and it great. It has 60MHz 500MS/s 10Mpt 2 Ch and the price is great $349.00. the model is SDS6062. Saelig has a video on its operation review.
