So, I have a single input pin left on my microchip. My code has 2 modes, depending on the input type to this pin. When the code starts, a 0V on the pin indicates one mode. Otherwise, it moves on to the other mode. In the second mode, the input is receives data that has a 5v resting state.
I need to figure out how to explicitly keep the data line low at start up while keeping the high data stream off. Any ideas?
I thought I could simply control the power to the data device with a npn mosfet, so there is no data stream until I turn it on. However, the input pin is sensing some voltage (or the pin is floating). I thought about a pull down, but since the data line is resting high and has a pull up resistor, isnt this an issue?
