Hello:
I have a project where I need a very small actuator or solenoid. I need to
pull a lever about 1/4 to 3/8". As an aside, I don't understand the
difference between an actuator and a solenoid.
Where can I find such a thing?
Thanks for the help!
Dan
You don't say how small very small is or how much force you need.
A solenoid is an actuator, not all actuators are solenoids.
In automobiles for trunk latches and such they use a motor driven
actuator that works a worm screw and provides a lot of force in a
small size compared to a solenoid.
We used a similar scheme in RC in the 60's - small toy motor spins a
long screw or threaded rod and a follower nut moves a slotted lever to
move a rudder on boats. Cheap easy, proportional, simple and
powerful.
In small radio control toys they use a magnet pulled left or right by
coils like a solenoid.
"Voice coil" (ala speaker) drives are used to move arms in hard drives
and focus lasers and digital camera lenses. Precise positioning not
just in or out.
Look into Radio Control hobby sites for servo actuators (motor driven,
geared, precise positioning)
Springs, bimetallic devices or "muscle wires" that move due to heat or
current flow.
Simple solenoids have unequal force depending on how far the plunger
is out - they can incorporate machined plungers and pole pieces to
correct that shortcoming.
