need simple microphone pre-amp opamp circuit
Discussion in 'Electronic Design' started by [email protected], Feb 18, 2006.
  1. Guest
    I have to throw together a simple op-amp based electret microphone
    pre-amp circuit on the road (limited access to hardware) - yes I feel
    like Mcguiver.
    I have access to a LM357 op-amp that I need to use with a single 6v
    supply.
    Anyone have a simple circuit that will work with a single supply
    powered op-amp?
  2. Phil Allison
    Phil Allison Guest
    ** Don't you mean the LF357 ?
    ** Although this op-ap is not spaced by Natsemi to operate with less than
    +/- 5 volts supply - it will still function with reduced specs with a 6
    volt single supply.
    Just use a standard inverting amp stage and bias the + input to 3 volts.
    Suggest the input resistor be 3.9 kohms and the feedback a 250k ohms pot.
    ........ Phil
  3. Google for "opamp electret mic preamp" (without the quotes).
