Need replacement of NEOSID Ring Core
Discussion in 'General Electronics Discussion' started by Rleo6965, Jul 4, 2013.
  1. Rleo6965
    Rleo6965
    585
    9
    Jan 22, 2012
    Hi, This time I need your expertise finding equivalent of NEOSID 17-732-22 Ring Core 14.8X8X6.35mm. I think its now obsolete part.
    I need this core as filter choke to avoid 22khz spike from center tap of push pull transformer going back to 12V Car Battery.
    I have already build this dc inverter and working properly and I temporary use core from ATX PSU and wound 12 turns of 1 mm enameled wire to have 6.5uH filter choke inductance.
    Now my problem was I need 10 pcs of equivalent or replacement of NEOSID core. After googling. I found out that NEOSID 17-732-22 have a Grade=2003, Saturation Flux Density=15,000 gauss and Max Freq = 500khz.
    I search in RS and I don't know the equivalent MATERIAL to be able to search correct Ring Core equivalent basing those I mentioned above. I only need the correct core only.
    http://philippines.rs-online.com/we...-by=default&sort-order=default&view-type=List
    Here's the link about core material
    http://www.universal-radio.com/catalog/misc/amidonT1.html
    As I mentioned before. I'm not graduate of any Electronic Engineering Course. I'm self study electronic engineer. :D This the reason I need your expertise.
  2. Rleo6965
    Rleo6965
    585
    9
    Jan 22, 2012
    Just figure out correct material after researching in internet and its not available in RS and Farnell.:(
