Jamie
We need 4 arbitrary capable function generators
What I've found that looks interesting so far.
http://www.tequipment.net/BK4045.html
We need to use the arbitrary function to control
a steering system in irradiation units so that we
can guide the electron beam around a couple of obstacles
that are causing some ripples in the path during the sweep.
I want to attach a arbitrary generator to the steering
amplifiers (x,y) and have it gated from the scan signal.
I would like to know how well the arbitrary editing performs
on this unit, before we go out and buy a few.
I need to generate at least 2 sinusoidal in a DC offset
curve. The sweep time for the total pattern will be 100Hz
or 200 Hz and we'll use the computer system to talk to it
when the operator is setting a job.
Do you think this unit gives enough way points in a 200 Hz
time window to generate 2 sins/cos on a DC offset ramp ?
And how reliable do you think this unit is?
What we have now on one process is a Atmega with multiple
DAC(PWM) outputs driving differential amps into a summer. We talk to
this uC via RS-232. it works but it's custom made in house (by me)
and they want to tool the machines with off the shelve replacement
components.
Thanks.
http://webpages.charter.net/jamie_5"
components.
Thanks.
