Hello
I connect this led to a 12 volts battery ,i put led mounted on heatsink.
I notice less one second led get so hot that it melt solder off the wire that connect to led.
I connect led direct to 12 volt battery since led is rated for 12 volt.
So what am i do wrong?
Included in this thread detailed description of the led , from goldmine.
Detailed Description
Super power LED type CL-L220-C16N-A by Citizen produces a typical luminous flux of 1150 lumens. This LED is seriously powerful. Produces a blinding cool white light that should not be viewed directly at close distances as it is just too bright to look at. Operates on 10.5V to 12.9VDC at up to 1.68Amp. Note this LED must be mounted to a heat sink and should be used with a current regulated supply. Overall size 1.1" X .7" X 0.035" thick. Actual active area about 0.55" square. Active area contains about 72 powerful tiny white LEDs. Brand new .
mrel
mrel
