Need motor specification
Discussion in 'Sensors and Actuators' started by questraman, Oct 15, 2016.
  1. questraman
    questraman
    4
    Oct 15, 2016
    I have an old motor and would like to use it in a project. I need specification details of the motor. Its model is, rk-370sd-4035. Tried google, unable to get the details of Amps and Voltage.
    Any help?
  2. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    What motor technology? Universal, DC, Induction?
    A photo would help with an indicated physical size.
    M.
  3. questraman
    questraman
    4
    Oct 15, 2016
  4. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    You may have to do some empirical tests, run it on low voltage DC and check rpm and current.
    Probably a small PWM controller would run it.
    Unless specially designed, the rpm is commonly around 3krpm.
    RPM is proportional to voltage.
    M.
  5. questraman
    questraman
    4
    Oct 15, 2016
    After searching google, i got this...https://ru.aliexpress.com/item/Orig...eed-370-Threaded-Shaft-Motor/32433129909.html It is given as 12 V. How to find the Amp?
  6. davenn
    davenn Moderator
    13,810
    1,944
  7. Bluejets
    Bluejets
    4,752
    999
    Oct 5, 2014
  8. questraman
    questraman
    4
    Oct 15, 2016
Similar Threads
Loading...
