Need information about pulse shaping amplifier
Discussion in 'General Electronics Discussion' started by Ejaz484, Mar 10, 2011.
  1. Ejaz484
    Ejaz484
    6
    Mar 10, 2011
    Hi 2 all...
    I need to design a pulse shaping amplifier for my project...
    Iam not getting how to select the R,C values for different input frequencies...
    Can anyone explain me how we select different RC values for different input ramp signals frequencies
    Thanks......
  2. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    If you are talking about generating a ramp at a given frequency, then you will have a capacitor in the feedback loop of an op amp, forming an integrator. Capacitance is defined as the ratio of charge to voltage or the change in charge for a change in voltage. C=Q/V=dQ/dV=IdT/dV where I is related to R and the time differential is related to frequency. Just how these are related depends on your circuit.
    If you are talking about filtering a ramp signal, or filtering a pulse train, then you will need to be more specific about what the filtering is intended to accomplish.
    Arouse1973 likes this.
  3. Ejaz484
    Ejaz484
    6
    Mar 10, 2011
    Thanks for ur response sir,
    sir actually i want to design the pulse shaping amplifier to which input is ramp signal...
    The frequency of the ramp signal may be 1MHz or 5Mhz. So I have to design a pulse shaping amplifier...
    Iam not getting how to consider the R, C values for different input frquency signals....
    Thanks....
  4. Ejaz484
    Ejaz484
    6
    Mar 10, 2011
    Thanks....
  5. pretty_fly
    pretty_fly
    Feb 2, 2015
    Hello Ejaz484 did you have any achievement about your question?? I need something similiar.
