Need info on vintage General Instrument Mosfets
Discussion in 'Electronic Components' started by wa2rqy, Nov 26, 2008.
  1. wa2rqy
    wa2rqy Guest
    Hi All;
    I got a bunch of these older GI Mosfets but really was not able to
    find much info on the WWW.
    Any info would be helpful.
    I think they are from around 1976 or so and in plastic boxes marked:
    MEM520
    MEM556
    MEM554
    MEM2008
    They were part of an Electronic Engineers stash of samples I guess?
    Tnx,
    Rich
  2. legg
    legg Guest
    1976 is quite early for these devices to be power mosfets. IR and
    Hitachi only started commercialization around that time. Are these
    date-coded? Are you sure you've read the logo correctly? What case
    size (TO3 metal most common, at that time)
    There were a lot of mosfet fabs that fell afoul of IR's patents in
    this period.
    GI did have power mosfets (Y-MOS)listed in their '86 catalog, which
    disappeared from the '87 catalog (after GI absorbed Varo).
    Part numbers were constructed
    P - Mosfet
    A,B, C - 60, 100 or 150V - Vds
    XXX - power rating in watts
    N - n-chanel
    xxx - Rdson in milliohms
    L,S,H - 0.8, 2.0, 4.0 - threshold voltage
    P,M,T - To218/to247, to3, to220 package.
    So a typical part was PA125N40SM
    RL
  3. Phil Allison
    Phil Allison Guest
    "wa2rqy"
    ** According to my transistor /fet data book from1976, all the above are P
    channel junction fets in TO72 cases.
    Vds = 25 to 60 volts, Pd = 125 to 200 mW
    ** Dunno - but more likely a mosfet.
    ....... Phil
  4. wa2rqy
    wa2rqy Guest
    Great, thanks Phil:)
    I knew I cud count on you guys!
    Regards,
    Rich
  5. Phil Allison
    Phil Allison Guest
    "wa2rqy"
    "Phil Allison"
    "wa2rqy"
    ** Do you want the rest of the data on the first three ?
    ..... Phil
  6. legg
    legg Guest
    Towers shows
    MEM520 - 30V 50mA 250ohm PMOS-enhancement mode rf switch (2.5pF Ciss),
    MEM556 - 80V 20mA ~same (0.5pF Ciss). Both in TO72
    MEM554 - 20V NMOS dual-gate low frequency amplifier.
    RL
