hello everyone this is my first time being here at EP and am glad i found this place. I am having some problems getting my TIP-127 PNP to work properly. here is some background info on what i am trying to do.
Pic16f88 programmed with 3 outputs each of these 3 outputs go to the Base pin on the TIP-127. One of these outputs Will be a PWM output.
My logic for switching the TIP127 on is correct in the software (Logic 0 turns Tip on)
if i measure the output pin of the PIC outputs are acting proper to what i have programmed.
I plan on driving 3 solenoids at 22ohms@12v here is my calculations
using ohms law i calculate .545 amps draw at solenoid.
Minimum base current=545ma/1000hfe=.545ma+a lil to ensure full saturation so .700 sounds good?
Rbase=12/(.545/1000*.7)
Rbase=32K ohms
Power dissappated= .3(.545)=163mw
my problem is when i have a high condition on the output pin,my TIP is at 12v on the collector(no load-just measured with a volt meter) When the output pin is brought low the TIP is still at 12v.
This is the first time i have worked with a TIP transistor and am clearly doing somthing wrong. can anyone help me understand whats going on here. ill check back often if anyone has further questions.
Jason
Rbase=32K ohms
Jason
