Need help with these basic electronics question?
Discussion in 'Electronic Basics' started by Top gear winner 2, Aug 7, 2005.
  1. Hi I am learning basic electronics and I need help with these
    questions?
    1. The resistance of wire does not depend upon the
    A. type of insulation around the wire
    B. length of the wire
    C. temperature of the wire
    D. Type of material used to make the wire
    2. Wires from a cable to a terminal block are purposely curved.
    That is properly called
    A. stress relief
    B. strain relief
    C. a dynamic curve
    D. frontal routing
    Thanks for your help
  2. What are your thoughts on these questions - which answers look likely
    or unlikely to you, and can you explain why?
    To me, the answer to Question 1 should be obvious, with very little
    thought, but I might accept either of two answers for Q. 2. However,
    I don't want to simply tell you the answers, because you won't learn
    much that way.
    If you tell us your thoughts, we can either confirm the answers, or
    discuss the errors in your reasoning.
    Peter Bennett, VE7CEI
    peterbb4 (at) interchange.ubc.ca
    new newsgroup users info : http://vancouver-webpages.com/nnq
    GPS and NMEA info: http://vancouver-webpages.com/peter
    Vancouver Power Squadron: http://vancouver.powersquadron.ca
  3. Comteck
    Comteck Guest
    in other words, you don't know the answer to these questions.
  4. JeffM
    JeffM Guest
    No, Grasshopper. Peter is a Socratic teacher
    http://en.wikipedia.org/wiki/Socratic_method
    who doesn't believe in doing other people's homework.
  5. Hey, he handled it really well. The norm is to simply tell you
    to do your own homework. When you come up with questions like
    that, in that form, it is indeed homework. One can avoid that
    by actually phrasing the question rather than cutting and pasting
    the question (and answer), but once you can do that you are
    usually half way to an answer.
    YOu've given no indication that you've even looked at the answers,
    because then you'd be able to puzzle over them.
    Micahel
  6. Ban
    Ban Guest
    That is a little thin for a top gear winner.
    Both questions are so easy to answer, you just toss out the apparently wrong
    answers and there remain only the right ones. You do not need to know
    anything about electronics to answer them, just a tiny bit of intelligence
    is enough.
  7. Pig Bladder
    Pig Bladder Guest
    This is a gag, right?
  8. Rich Grise
    Rich Grise Guest
    No, we know the answers, we just don't do other people's homework
    for free.
    Cheers!
    Rich
  9. 1: D
    2: C
    Good Luck!
    Rich
    "I'm glad we don't have to play in the shade."
    -- Golfer Bobby Jones on being told that it was 105 degrees in the
    shade.
    "Very few blacks will take up golf until the requirement for
    plaid pants is dropped."
    -- Franklyn Ajaye
  10. John Fields
    John Fields Guest
    Those questions have been posed in an effort to try to get _your_
    brain to work, not to get ours to work _for_ you.
    You need to look up the resitivities and temperature coefficients of
    resistance of various conductors and then, if you still have
    questions, come back and I'm sure we'll be happy to help you.
  11. me
    me Guest
    if in an exterior application it would be a "drip loop"....
  12. One of those answers is applicable, though.
    Tom>
  13. PeteS
    PeteS Guest
    I (as a past teacher of electronics) would suggest a focused reading
    assignment. Although I wouldn't normally post a direct link (because
    figuring out how to find information is part of the exercise), in this
    case one must read the information to get the answer for question 1:
    http://en.wikipedia.org/wiki/Ohm's_law
    For question 2, one might go looking up such things - there are many
    names used - in this case it depends on which author one has been
    expected to read.
    Cheers
    PeteS
  14. quietguy
    quietguy Guest
    That was mean, Rich
    David
