Need help with simple IR remote circuit
Discussion in 'Electronic Basics' started by Jack B. Pollack, Jul 31, 2004.
  1. Can someone recommend a simple IR remote receiver circuit that can
    understand about 20 commands.
    I am looking for a simple circuit, or a device that I can cannibalize. The
    outputs are going to drive bi-directional switches.
    The IR signals will ultimately be transmitted by a learning remote. I would
    prefer not to have to build the initial transmitter if I could use a
    pre-existing remote unless the transmitter circuit is very simple.
    Thanks for your help.
  2. Richard
    Richard Guest
    Jack,
    Check the ELM339 - Infrared Remote Control
    from Elm. It will control 3 devices:
    http://www.elmelectronics.com
    Otherwise I see a lot of tossed out VCRs and remotes in the garbage
    and for a few bucks at garage sales. You could hack the remote board
    directly or take the IR sensor out of the VCR and use the remote to
    transmit
    digital words to a PIC you programmed. Which I usually avoid.
    a lot of IR info at:
    http://www.epanorama.net/links/irremote.html
    Good luck
    Richard
