ScruffyNerfHerder
- Oct 3, 2015
- 2
- Joined
- Oct 3, 2015
- Messages
- 2
Hello! First a little information:
I have an idea to create a round wooden "box" (approximately 13-14" wide) that will have something on display inside of it. The box will also have a round lid. There will be a "false" bottom that the item will sit on and will be connected to the top via wooden dowels. The weight is no more than 2 lbs. I want to push a button (or flip switch) and the lid will raise up bringing the false bottom and item up to be retrieved. The item is 6" tall, so I would need about 6.25" of lift. I would like this to be battery powered.
So here is my question:
What sort of apparatus should I use to lift this? electric actuators? mini scissor lift? If you could include hyperlinks to the equipment, that would be extra helpful. Thank you all in advance!
